Hi all. I wasn't sure where to put this post, but since it does have to do with "playing", maybe its not such a bad place after all.
Is anybody familiar with the ffmpeg -vcodec xvid or libxvid builds and playability in virtualdub ? All the ones I have seem broken and only play in KMplayer; VLC; or MPlayer, (they also play perfectly in both my WDTV and LG portable theater player devices) but i'm wondering if its a "header" thing, where I ight have to hack it to work inside virtualdub.
For the ffmpeg(s) I have, mediainfo says each are either of:
Lavf51.10.1
Lavf51.12.1
I'm looking for the correct or best (xvid encoder) version ffmpeg to download. I'm trying to build a gui around it (just for me personally) but just for xvid (batch) encoding purposes but am stumpped with the above limitation because I cannot analize the video encodings for quality purposes
Thank you,
-vhelp 5181
tags: xvid wont play in virtualdub fourcc divx vtag param XVID
	[RESOLVED] 9/4/2009 Fri pm
 HORRAY!!
 after a little more digging around through google, (was my friend this time around) I found the answer.
 ffmpeg -vcodec xvid -vtag XVID
 you have to use all caps. Now opens perfectly inside virtualdub vdub .
 -vhelp 5183
  Trying to encode a clip to XviD to join another using VirtualDub ...By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 03:08
  [Resolved] Making 2 AVIs the same so that VirtualDub can append?By Diana (Cda) in forum DVD RippingReplies: 32Last Post: 9th Dec 2010, 15:01
  I need a supported build of ffmpeg for Avanti 0.4.8By flashandpan007 in forum Video ConversionReplies: 1Last Post: 23rd Jun 2010, 10:28
  *RESOLVED* resetting password on a networked HP printer? *RESOLVED*By Xylob the Destroyer in forum ComputerReplies: 3Last Post: 21st Nov 2008, 14:50
  Help! I'm going crazy trying VirtualDub to encode to XvidBy hdnine in forum Newbie / General discussionsReplies: 9Last Post: 17th Dec 2007, 09:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
